Check and make sure that the screws themselves are tight, even though the connector moves... Otherwise be prepared to have to open your dash up to fix the problem...
Yeah, really.
Luckily I didn't have to go apeshit on my dashboard to get it out, but it is a bit unnerving when that happens. At least you had one screw left, mine had to be pulled out with only the solder joints and wires.
