Well I finally hooked up the hyper terminal just to see what it could do and i found some wierd characters in the boot log..here ill show them..
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v276 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jun 12 09:25:39 EDT 2002
empeg-car player (hardware revision 9, serial number 10101521)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:f
1
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5 chan
ge_root: old root has d_count=1
Freeing unused kernel memory: 4k init
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
What is that wierd stuff after " Press Ctrl-A to enter pump"
Could somone tell me please.
Ben
Ben
mk2a 60gig green/Greenlights Buttons
mk2a 40gig blue no illumination....yet
hijacked
