I've found that since those basic premises have changed, there's a lot more uniformity in what gets rendered. So, given that few browsers actually support SVG, if you stick with using style sheets (or something newer than that), you'll end up seeing something more regular across browsers.
BTW, to be less snarky, you'll notice that the HEIGHT tag is marked as deprecated in the HTML spec.
