Daria
Loc: Providence, RI
Turning off the GPS when you shut down and not moving it while it's off should be sufficient to deal with the problem you highlight. It's the same as the Earthmate hardware. As they say, it's not a cold start.
The cold start problem can be "solved' with another patch, which tweaks the GPS state to hint to it to not fall back to cold start so easily, which I will try to come up with later.
