...there's lateral thinking for you, and some valid points.
BTW, since you're going to be in an area that probably has some wonderufl views, make sure that whatever camera you choose has a wide angle capability similar to a 28mm lense. Even if it's a screw on lens adapter (these tend to run at $50+). There's nothing worse than having a wonderful view, and only being able to get 1/2 of it in the frame.
