e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v291 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jul 31 10:10:42 EDT 2002
empeg-car player (hardware revision 9, serial number 30102349)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9f750
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:2
d
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N13
serial_notify_thread.cpp: 117:@@ F0x720
serial_notify_thread.cpp: 118:@@ TJellyhead
serial_notify_thread.cpp: 119:@@ ACrush
serial_notify_thread.cpp: 120:@@ G
serial_notify_thread.cpp: 180:@@ #720 0:00:48
serial_notify_thread.cpp: 170:@@ S1
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 7659
52, error=0xc0044000
serial_notify_thread.cpp: 180:@@ #720 0:00:49
serial_notify_thread.cpp: 180:@@ #720 0:00:50
serial_notify_thread.cpp: 180:@@ #720 0:00:51
serial_notify_thread.cpp: 180:@@ #720 0:00:52
serial_notify_thread.cpp: 180:@@ #720 0:00:53
serial_notify_thread.cpp: 180:@@ #720 0:00:54
serial_notify_thread.cpp: 180:@@ #720 0:00:55
serial_notify_thread.cpp: 180:@@ #720 0:00:56
serial_notify_thread.cpp: 180:@@ #720 0:00:57
serial_notify_thread.cpp: 180:@@ #720 0:00:58
serial_notify_thread.cpp: 180:@@ #720 0:00:59
serial_notify_thread.cpp: 180:@@ #720 0:01:00
serial_notify_thread.cpp: 180:@@ #720 0:01:01
serial_notify_thread.cpp: 180:@@ #720 0:01:02
serial_notify_thread.cpp: 180:@@ #720 0:01:03
I sure hope this mean something to you, LOL.
