Well, I could write something
Or if you have access to a laptop you can just drive the area and capture the nmea output from your gps via hyperterminal (or your preferred serial app). I did this a couple of times when I was testing stuff for Kim's gps software. You could do it with the empeg as well, but you would have to have the drives mounted read/write and it gets more complicated from there.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
