Greetings!
Yes, crashing while moving is not good - scattered with bits of plastic from broken jewel boxes everywhere!!!
The case is the same for all of the versions. The XG viewpacks are very similar to what I have.
The archival packs do not have the foldover piece. They just have a clear plastic pocket in front and back, with a protective pocket in the center. The outer booklet fits in the front pocket, the back artwork went in back, with the CD safely in the middle of the protective layers.
The trick, and this is a problem with all of the version of this system, is that the pockets are all the size of the CD! The back artwork is bigger, so it fits awkwardly, turned at a 90 degree angle. Also, any CD that does not fit this booklet format (either cardboard sleeves, oversized books, etc) does not fit well.
It is a nice system, as long as the booklets fit gracefully. If you would like to see a sample, PM me with a mailing address. I have a few different types of these lying around (archival and black viewpack that I can remember off hand...).
Paul Grzelak
