My, that was quick. Looks like it was only a couple of hours between your original post asking for recommendations and the final purchase.
If we'd known we had a deadline, maybe we could have worked a little harder at getting some recommendations prepared.
Sounds like you're pretty well set, since you got the Aux-in adapter. Did you get a mounting kit and wiring harness, to? Does your dash have a double-din opening, and is the mounting kit going to cover both openings?
One final note: You got a Kenwood receiver. The Empeg's remote sends kenwood commands. You might be forced to cover or disable the Kenwood receiver's IR input, or else it might respond to all the commands you intend for the Empeg.
___________
