The boot log looks like this...
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@cushman) (gcc version 2
.95.3 20010315 (release)) #1 Mon Mar 10 06:11:37 EST 2003
empeg-car player (hardware revision 9, serial number 10101450)
Command line: mem=16m
Memory: 15024k/16M available (972k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
a
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
mount: /programs0: No such file or directory
Using /etc/preinit.d as startup script directory
empeg-preinit complete
empeg init 0.8
Mounting proc
No secondary hard disk
Starting player
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
khttpd: listening on port 80
kftpd: listening on port 21
start_empire: sleeping for 10 seconds...
! tags.cpp : 61:Failed to open tags (0xc0041002).
start_empire: Starting Empire...
IrDA: Registered device irda0
irlap_driver_rcv(), Unknown frame ef received!
Vcb: 0x4086d000
-Michael West
