What is that bracket for, your rally computer?
It started out as a temporary thing, but as ugly as it is, it is very functional. We may keep it. Just a length of Home Depot aluminum angle bolted to project box with lots of velcro on the angle to hold a clock/odo and ham radio like so
Sweet. I'd love to see a shot of that all hooked up.
So would I, brother, so would I!
When I get back from Amersfoort, I should have a new Timewise 798A waiting and I'm going to spend about 4-5 quality days in the garage. Pull out all of the seats and finish all wiring, new subwoofer, maybe some raammat. I now have the second glovebox that I am going to hack for a mount for the Timewise. I *will* take pictures when I am done!
As for the space... i've seen it done with a standard DIN lcd slide out screen type thing in many pics on NASIOC, so i figure it's gotta fit somehow. Thought the empeg's sled might be a hindrence.
Yeah, I was probably being too pessimistic, and that pod is probably taller than I realize.
If you did mount the Empeg down below, would you be content with it as your only head unit?? The reason mine projects out a bit is because the 2-HU install pushes it so high up. If you could mount yours 1/2" lower, it could sit much more flush, esp with the morrisdl treatment....
....and you could put some gauges or something else below....
Jim
