I have a question in regards to Eternet connection to the empeg. Everything works fine with no problems for me, however in the initial screen of Emplode it finds the empeg Twice (same empeg, same ip address) ... I can click on either and it works fine, however i'm curious what might be causing this?
The empeg is plugged into a Router which also has the computers plugged into. Router has it's own DHCP server, however it has been disabled for now and is using direct ip configuration (which has been setup in the empeg).
--verteggio
