i'm replacing the disk with a 40 gig.
i tried loading the builder but i'm not sure if it completed because it wouldn't complete the 'finding pump' type message ... basically i don't thjnk it ever shut down and restarted as per the upgrade instructions say it would. however, i have the newest emptool updated..
heres the complete output from the time i turn on the player:
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 (release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 10101611)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005f00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:4b
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... Kernel panic: VFS: Unable to mount root fs on 03:05
thanks for the help,
Marco
