Greetings All,
I'm a new empeg user having just purchased a MK2 via ebay. Wouldn't you know it, it arrive DOA. The seller promised me that it was working great when it was shipped, but somehow it is now displaying the infamous "No hard disk found" message. I managed to connect to the unit with minicom and here is the output-
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 (release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 10101767)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: ÿ, ATA DISK drive
ide0: unexpected interrupt, status=0x58, count=1
hda: ÿ, 2088991MB w/32640kB Cache, CHS=65535/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:e7
Partition check:
hda:hda: status error: status=0x58 { DriveReady SeekComplete DataRequest }
hda: drive not ready for command
ide0: reset: master: error (0x00?)
hda: set_geometry_intr: status=0x51 { DriveReady SeekComplete Error }
hda: set_geometry_intr: error=0xff { DriveStatusError BadCRC UncorrectableError SectorIdNotFound TrackZeroNotFound AddrMarkNotFound }, CHS=65280/0/81, sector=0
hda: read_intr: status=0x51 { DriveReady SeekComplete Error }
hda: read_intr: error=0x00 { }
end_request: I/O error, dev 03:00 (hda), sector 0
unable to read partition table
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
Can anyone help me interpret this spew? Is my hard disk dead? I know the shock absorbers in these things are great, so could UPS really have messed it up in transit (the box appears in tact), or is it plausible that maybe a magnetic scan of some sort fubar'd the system and it just needs a re-intall? I have read the FAQ that everyone gets pointed to and have searched the forum, but I would still appreciate some expert advice from seasoned users.
BTW, I did crack the case and a preliminary visual inspection revealed nothing obvious was busted or loose.
Thanks for any help,
Ryan
