Good luck on your install, mine is still working perfectly. I'm happy with it. The pictures are gone.
![](/ubbthreads/images/graemlins/frown.gif)
I have looked all over for them but I seem to have lost them. This quote from earlier in the thread should help you.
In order to remove the existing stereo the dash panels must be removed. They are all interlocking and must come off in a specific order. This is for an option 8 USA Prius. Use this guide at you own risk. I don't guarantee the accuracy of these instructions, sorry.
1. Remove the bottom center section. There is one plastic "screw" on the passenger side. This panel will now pop out.
2. Remove the vent assemblies from the right side of the center console and from the far left drivers side( on left side of steering wheel next to drivers door). These panel just snap off. It is the entire silver panel.
3. Bottom dash under steering wheel. There are two screws in the bottom of this that need to be removed. Then just snap it off. It's attached with wires and the hood release so it will just hang there.
4. Upper dash above steering wheel. This one just snaps off. It also is attached by the start button.
5. Vent left of center console. This one just snaps out. You can disconnect the park button so it can be removed.
6. Remove the two 10mm screws holding the touchscreen in and pull it out. It comes out by pulling it directly back. Disconnect the four cables going to it and put it in a safe place.
7. Center console piece below stereo. This just snaps out.
8. Remove the two lower and two upper 10mm bolts that hold the existing stereo in and yank it out. Disconnect the 3 cables going to it.
Thats it!
The one thing I can't stress enough is to take great care in the placement of the rio sled within the existing audio metal frame. This is essential in order for the rio to line up correctly with the opening and for it to be located at the proper depth. It was the hardest part of the install.
Charles
No matter where you might be, there you are.
