Also on the EXEC thread, I'm planning to rename these macros to simpler, lowercase versions, like nearly all of the other Hijack config.ini settings.
Thus, ";@EXEC gpsapp" will become "exec gpsapp" or possibly "exec=gpsapp". There are definite coding advantages to this.
The ;@AC/DC and ;@HOME/WORK macros will remain as is, because the leading ";" is necessary for them to work (outside of the [hijack] section of config.ini).
This change will likely happen in (edit:) v362, with an overlap period and warnings for the existing syntax.
Edited by mlord (26/01/2004 12:44)
