The box knows the time; it's in all the http responses. The server can easily be NTP synced.
An alarm clock is on the wishlist, but with provisos: there's no RTC, so it needs a server connection (also needs one to be able to play some noise, though it could make beeps I suppose). If the input power goes off/on, the unit will not start the CPU until you press the power button - so it would miss alarms in this circumstance.
Hugo
