well, the clean hijack kerne did not help but programmed successful...
here is the actual hypertpaste
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)bing primary interface...
r10 = 4001D
hda: TOSHIBA MK4018GAS, ATA DISK drive
or forever hold their peace...it seems not. Let fly the Penguins of Linux!F
e000 v1.04SHIBA MK40
Copying kernel...ive00000 r4 = 00
Calling linux kernel...
Uncompressing Linux..................................... done, booting the kerneon irq 6
init(1): memory violation at pc=
hda: TOSHIBA MK4018GAS, 38154MB w/0kB
l.ch
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v395 (mark@rtr.ca) (gcc version 2.peg-flash driver initializedr10: 4001d858 r9 : 00000000
smc chip id/revision
95.3 20010315 (release)) #2 Sun Jun 27 17:52:49 EDT 20046 by Erik Stahlman (erik@vt.edu)
Processor: Intel StrongARM-1100 rev
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)C: 000000157 = 40000230
Dentry hash table entries: 2048 (order 2, 16k)m [<40003998>]20 r4 = 4001E16050>] lr : [<
r10
Page cache hash table entries: 4096 (order 2, 16k)00000]p : bff
IP Protocols: ICMP, UDP, TCP
Function entered at
TCP: Hash tables configured (ehash 16384 bhash 16384)f994 r4 = 00000000
r10 = 4001D858 r5 = 00000000 r4 =
Starting kswapd v 1.55d35c r4 : 4012cc6c0
Function entered at [<400023e0>] fro
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART0062c r0 : 000
r10 = 00000000 r9 = 0000000
empeg dsp initialised
sp : bffff968 ip :
empeg remote control/panel button initialised.4001d858 r9 : 00000000 r8 : bffff99400
empeg usb initialised, PDIUSBD12 id 1012r10 = 4001D858 r5
r7
empeg state support initialised 0089/88c1 (save to d0004780).
Function
empeg RDS driver initialised
empeg power-pic driver initialised (first boot)1e440 r1 : 0000062c r0 : 0000000c = 00000000
empeg single channel IDE
r6 = 40
hda: TOSHIBA MK4018GAS, ATA DISK drive000000 r5 = 00000000 r4 = 00000000od
hda: TOSHIBA MK4018GAS, 38154MB w/0kB Cache, CHS=4864/255/630b750, lr=0x4000b738 (bad address=0x8003c660000015
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:2
0
Partition check:
hda:hda: status timeout: status=0x84
hda: drive not ready for command
ide0: reset timed-out, status=0x84
end_request: I/O error, dev 03:00 (hda), sector 0
unable to read partition table
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
what could i try now??
thanx for ur all help! dave
