- I wish for a checkbox on the "configure player" screen in emplode that says "Never allow the volume to go higher than 0db". (Unchecked by default, of course.)
I second this. I seem to always get distortion when I accidently turn the volume up past 0dB.
- I wish that there was the possibility to simultaneously set up more than one ethernet configuration on the empeg. When switching between work and home, I must reconfigure the empeg to use either DHCP (work) or fixed IP address (home) before it will respond on the ethernet cable.
This one would be great, too. Though I happen to have the opposite configuration: DHCP at home, static IPs at work.
cu,
sven
(MkII 12GB blue, #080000113)
proud owner of MkII 40GB & MkIIa 60GB both lit by God and HiJacked by Lord
