I'd thought I would run this by you guys cause I know you guys rule. I'm gonna kinda break this up into sections. Sorry for the length but I hope its an easy reader.
I built a computer with a Koolance case pre-installed with the water cooling. I have a MSI Neo2 MB with a P4 3.0 GHz. I also have an ATI Radeon 9800 AIW. I have two HD and a DVD-RW and CD-RW. I also have a Sound Blaster Live. I attached the water cooling to the CPU, Chipset and VIdeo card. My PSU is a Hercules 450W.
So I moved and need edto get a wireless card for my computer. I decided on getting a linksys PCI card. It was their newest with the Speedbooster technology. After I installed it it would work but I started having some troubles with my computer locking up. FInally I left my computer for an hour and came back to find the blue screen of death. I reset the computer but it went to a blank screen and wouldn't boot. So I pulled the power cord to completely shut it off. I waited a couple of minutes and plugged the cord back in. I hit the power button and nothing happened. I tried removing all sorts of components and did the bare miniumum but still nothing. I even jumped the ATX connector to see if the power supply was bad and it still powered my water cooling. I decied to send the board back to MSI.
Now I get it back yesterday and started putting everything back together. I reset the CPU that i stored in a static sensitive bag and reset all the hestsinks for the water cooling. I plug in powercord and hit the power button and it turned on. However this time the system halts with nothing appearing on the screen. I looked in the back and the D-Bracket showed all four LEDs as red. I looked it up and it indicated that the CPU was either not installed corrected or it has been damaged. I reset it again and made sure that I applied pressure and that it was all the way in. Nothing again. I unplugged all the devices and left just the Video Card, Memory and Water cooling hooked up to the power supply. Same result. I cleared the CMOS with the jumper and still no luck. I searched around everywhere and couldn't find any solid solution.
So to wrap up this story, I'm thinking that the wireless card pushed the limit of my Power Supply and caused a short. Or the card somehow damaged my CPU which sucks because I took off the warrant sticker that was on the top of the chip. Does anyone have any ideas? Thanks for any help.
