#244011 - 14/12/2004 19:16
Re: TTS Clock Install Problem
[Re: Qtqc]
Quote: Im using a Linksys router and Im pretty sure theres a Networking or Ip reason why its not working.
The quick way to verify this is to see if you can connect to hijack's web interface by going to http://192.168.1.102 and seeing if it connects at all. If you can do that, then FTP should work as well and it's just a question of getting the right commands going and such.
You probably just need a proper piece of FTP client software that shows you what's happening on the hard disk. Have a mess-around with CuteFTP or WS-FTP and see what it does.
You can also use an alternate method for putting files on the player.
