I'm not sure I understand the problem. First you say all is okay, except it needs to be moved to the right by one character, but then you say the inter-cell spacing (whatever that means) is double what it should be. What's the problem again, or are there two problems? Thanks.
I can get the stuff to print properly spaced using my own printer setup and escape codes that are the defaults but everything needs to be moved to the right by one character.
One might think this could be addressed by setting item 5 (Beginning of Line) to contain a single space character.. decimal 32 or hex 0x20.
