Greetings!
Two other thoughts that you might want to look at. The switch may not be handling the empeg properly, but (if you are able to connect) that is probably not likely. Another thought - if your PC is at 100 and the empeg is at 10, the switch would have to bridge your speeds. That might be a huge bottleneck. You might want to try forcing your PC down to 10 and see if that helps throughput to the empeg.
Random thoughts...
Paul G.
SN# 090000587 (40GB Green)
Paul Grzelak
