Bootlog: (w/ hijack ir translate errors i've been too lazy to fix)
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v345 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Thu Oct 16 17:41:00 EDT 2003
Processor: Intel StrongARM-1100 revis
empeg-car player (hardware revision 9, serial number 40103852)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9c388
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:0
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Hijack: intercepting config.ini
[hijack] ERROR: "80B800CE=20DF10"
[hijack] ERROR: "80B800CF=20DF11"
[hijack] ERROR: "80B800C9=20DF16"
[hijack] ERROR: "80B80006=20DF0C"
[hijack] ERROR: "80B800CB=20DF12"
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
