Keep in mind that if you go with the WET11. you'll have to run your network in mixed mode (802.11b/g) and the transmission rate of your (g) clients will drop precipitously
If I have my current router set up to do mixed mode, and it only has one client so far (the mac), and the client is set to connect at G, am I slowing down the network anyway just because I've configured it for mixed mode?
he one caveat I'll add is I wasn't able to get client mode working on a WEP-encrypted network, but WDS works fine over WEP/WPA, and has the added bonus of extending my wireless network's range. (If it's not obvious, WDS eliminates the need for client mode by bridging its 4 LAN ports to your WLAN.)
Would I need to set the central router (the Actiontec) any special way for this mode to work?
