Had a problem a few weeks ago where I received the dreaded 'no hard disk found' message. Decided to see if I could find out what the problem was and so took the player apart (thanks to the excellent FAQ). After nosing around I found a couple of possible issues with the IDE cable. One of the connections to the drives looked as though the connector had not been properly crimped to the cable:
And the connector to the motherboard didn't seem to sit flat, raising as it moved toward the right:
I did a bit of shoving on the cables and put the Empeg back together again and it does now appear to be working, but I'm a tad concerned as to how long it will last. Should I look to swap this cable out for long-term reliability or are the connections good enough?
Jim.
--Mk 2 S/N 080000154
