It was attached a few posts up, but here it is inline.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 40103200)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x1b49
smc_init couldn't find card
RAMDISK: Loading 320 blocks [1 disk] into ram disk...
done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
