Hello,
I own a empeg mark2 player for several years now. Yesterday I decided to reactivate it again, so I screwed the docking sled into my car, listened some tunes and pulled it out to get some new ones on.
I connected it to my home-network, but I couldn't get a connect. So I put my computer into some well known A and C class networks (which I usually use) and did a broadcast... without finding the unit.
So I took out my serial cable, connected it to the computer, but this didn't work either. USB connection was impossible because my windows xp doesn't want to accept the rio-provided usb-driver. It told me that there are missing files....
I thought of upgrading the system from the currently installed hijacked 2.00-final version 413 to 3.00-alpha13. I ran the emptool but it couldn't find the unit. Sometimes it was able to reboot it, but most time it just waits until the waiting delay was finished...
I couldn't believe it and started a hyperterminal session. This worked as supposed, so I grabbed logoedit and the newest hijack-zimage and received some weird "Error in status readcode 16" errors. This now really disappointed me....
I crawled the fabulous riocar-faq (many thanks to mr tony fabris) and found an entry called "Why does my player think it's at home when it's in the car?". I checked for the mentioned menu entries (dimmer, fader) and realized that my player still thinks that it is in the (a) car.
Ok, I re-checked the hyperterminal log and recognized the obvious line at the top telling me that the unit is running in "DC mode".
But I recognized another line near the top which makes me worry..
"c0c00000: wrote ffffffff, read e91ba9f0"
When I write "hello", I don't expect to read "goodbye", so I assume there is something wrong with the ram-module...
I hope that you guys could tell me some tipps and/or hints, what I can do except contacting empegrepair.com or my local trash-dump.
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
On DC power, quick boot
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
Checking for extra DRAM:
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel
empeg-car player (hardware revision 7, serial number 80000373) 12MB DRAM
Command line: mem=12m noinitrd
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
NET4: Linux TCP/IP 1.0 fo
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9b734
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004f00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:7
5
Partition check:
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k init
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
[ir_translate] ERROR: "PopUp1=Bookmarks"
[hijack] ERROR: "time_offset=2"
