Here is my boot up output..
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)dev 03:44 blksize=1024 blocknr=18661378 sector=3732
If there is anyone present who wants to upgrade the flash, let them speak now,inode bitmap -ou
EXT2-fs error (devi
attempt to access beyond end of deviceot
or forever hold their peace...it seems not. Let fly the Penguins of Linux!80read inode bitmap -IT
block_group = 227
e000 v1.04ctor=38305
Copying kernel...t=1empt to access
Calling linux kernel...04-0, 19077MB w/1806kB
Uncompressing Linux..................................... done, booting the kerneode bitmap -44
dev 03:44 blksize=1024 blocknr=18669570 sector=37339140 size=1024
l.un
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 (hijack@rtr.ca) (gcc version2-fs error (devi
attempt to access beyond end of deviceot read inode bitmap -10
2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006ad inode bitmap -2-f
block_group = 227
03:44: rw=0, want=19169283,
Command line: mem=16mss Ctrl-A to enter pu
Calibrating delay loop... 207.67 BogoMIPS=19169282 sector=38338564 size=1024 count
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
EXT2-fs error (device ide0(3,68)): read_inode_bitmap: Cannot read inode b
Dentry hash table entries: 2048 (order 2, 16k) beyond end of deviceot read inode bitm
bloc
Buffer cache hash table entries: 16384 (order 4, 64k) read inode bitmap -2-f
bloc
IP Protocols: ICMP, UDP, TCP7474_inode_bitmap: Cannot re
TCP: Hash tables configured (ehash 16384 bhash 16384)evice
bloc
03:44: rw
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)ize=1024 count=1itm
03:44
Starting kswapd v 1.5tor=38371332 size=102
SA1100 serial driver version 4.27 with no serial options enabled inode bitmap -ou
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART23, inode_bitmap = 18210818_bitmap: Cannot read
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARmap = 19
empeg dsp initialised block_group = 2343,
bloc
empeg remote control/panel button initialised.tm
03:44: rw=0, want=19202051, limit=973728072
empeg usb initialised, PDIUSBD12 id 1012ev 03:44 blksize=1024 blocknr=19202050 s
empeg state support initialised 0089/88c1 (save to d0005e80).cess beyond end of deviceot read inode bitm
EXT2-fs error (de
empeg RDS driver initialisedbitmap: Cannot read inode bi
empeg power-pic driver initialised
ide_data_test: wrote 0xffff read 0xff80tmap = 18718722_bitmap: Cannot read ino
ide_data_test: wrote 0xaaaa read 0xaa80e ide0(3,68)): read_inode_bitmap: Canno
ide_data_test: wrote 0x5555 read 0x558026915, limit=9737280ice
P
ide_data_test: wrote 0x0000 read 0xff8045, inode_bitmap = 19210242or=37453828
ide_data_test: wrote 0xffff read 0xff80 to access beyond end of deviceor=34537
ide_data_test: wrote 0xaaaa read 0xaa80=0, want=19218435, limit=9737280 read i
ide_data_test: wrote 0x5555 read 0x55803:44 blksize=1024 blocknr=19218434 sect
ide_data_test: wrote 0x0000 read 0xff80e_bitmap = 18726914_bitmap: Cannot read
ide_data_test: wrote 0xffff read 0xff80nd of deviceot read inode bitmap -1024
ide_data_test: wrote 0xaaaa read 0xaa80limit=9737280read inode bitmap -
bl
ide_data_test: wrote 0x5555 read 0xff80locknr=19226626 sector=38453252 size=10
ide_data_test: wrote 0x0000 read 0xff7fevice: rw=0, want=16785411, limit=973
ide_data_test: wrote 0xffff read 0xffffread_inode_bitmap: Cannot read inode bi
ide_data_test: wrote 0xaaaa read 0xaaaa18743298 sector=37486596 size=1024 coun
ide_data_test: wrote 0x5555 read 0x5555p = 1922662680 read inode bitmap -ou
EX
hda: FUJITSU MHM2100AT, ATA DISK driveond end of deviceot read inode bitmap
hdb: IC25N020ATDA04-0, ATA DISK drive234819, limit=9737280read inode bitma
b
smc chip id/revision 0x3349map = 19234818_bitmap: Cann
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu) end of deviceocknr=18268162 sector=36536324 s
bloc
03
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:eev 03:44 blksize=1024 blocknr=19243010 sector=38486020 size=1024 count=1itm
03:4
7
Partition check:83, limit=973728
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
I also get this error when running fsck..
empeg:/empeg/bin# fsck -fay /dev/hdc4
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hdc4 is mounted.
The filesystem size (according to the superblock) is 19451880 blocks
The physical size of the device is 9737280 blocks
Either the superblock or the partition table is likely to be corrupt!
Edited by booey (29/08/2006 01:30)
