Tony highly recommend :
Kazama, I highly recommend you get your disks checked out, and also do a memory test
Here are the results of those memory tests for everyone to view. While no errors seems to stick out to me, you might see something I don't.
I powered down the unit, loaded up Tera Term, started the unit and hit Cntr-T. The following was the output:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
or forever hold their peace...
0000 empeg-car board test version 0.04
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0130 testing ic 3 (4-7mb, low word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IBM-DJSA-220
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 43
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
After that, the unit froze and wouldn't accept any commands. I am not sure if that is normal or not. I powered down the unit and powered it back up normally. This was the output I got from that:
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg41 (mac@aphex.internal.empeg.com) (gcc version 2.95.2 19991024 (release)) #135 Wed Jan 10 17:16:23 GMT 2001
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m temp=42
Memory: 10992k/12M available (972k code, 20k reserved, 296k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Logo type is 10
Scheduling custom logo.
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0004880).
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:10
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initDĀDÂI see this is a developer image!
Mounting proc
˙1P`@ JStarting player
empeg-car 1.02.
So I am not sure what to make of all that except that it seems to past the hardware tests.
This is my major curiousity. Since I only seem to have this problem when the unit is in the car, should I try and run those same diagnositc tests which the unit docked through the seriel port connector in the back of the sled? Just a thought.
Greg
