#289490 - 09/11/2006 12:29
Re: Safest way to ''jumper" something on a car....
[Re: Robotic]
Quote: It's only 12V, so just about anything will do- even a bent up paper-clip.
It's only 12v with a 500 amp supply behind it, so be careful. A sunroof motor may draw 25 amps, so an 18 ga wire would probably glow nicely.
See if you can determine the wire size already on the terminals and use that same size or bigger.
The circuit is probably already fused. Check the fuse box for one labelled sunroof.
Does the service bulletin call for this jumper to be permanently installed?
