#291474 - 15/12/2006 17:38
Re: copying tuner settings from one empeg to another
[Re: julf]
Quote: Don't forget that you can grab the entire /dev/hda3 by just FTPing into Hijack and doing get /dev/hda3
Thought about that, but will a subsequent "put" write it cleanly?
Yup. But if you do grab the whole partition /dev/hda3, then it will also be copying over the per-tune data sectors. No big deal, unless you care.. in which case you can truncate the file offline before doing the put.
No need to even enable "read write" access for the put, by the way.
Edited by mlord (15/12/2006 17:38)
