Okay, I give up. What do I need to click on in Gimp to change the colour?
Nice job on cleaning up the edges, how do you do that? I did the corners manually, but your method looks smooth.
Attached is a simpler xcf file. To change the lens color, select the "lens color" layer and then use the bukkit tool to fill that layer with the foreground color. Slide the layer transparency slider to get the right amount of opaqueness, then save as png.
299357-medium_fascia_transparent.xcf (909 downloads)
Mark Cushman
