#299089 - 08/06/200715:44Re: Vista/XP/Kubuntu tri-boot help
[Re: furtive]
tfabris carpal tunnel
Quote: It won't let me - says access denied.
If it says access denied when you run BCDEDIT, it's because you weren't running from an administrator command prompt. This is a new feature in Vista, unless you specifically set the command prompt to run as administrator (right click on it), then it doesn't have the right privileges to do serious damage.
The other option is to turn off UAC (that's in the control panel users section).
