Perhaps the file asociation for .scf files is broken.
To check/repair it run regedit then look in HKEY_CLASSES_ROOT\.scf -- it should look like the following:
If that looks okay then copy/pasting the following into a .reg file and double-clicking might change your computer's behaviour in this instance (this is a guess... it might bugger it up totally). Make a System Restore Point beforehand::
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\SHCmdFile]
"NeverShowExt"=""
@="Windows Explorer Command"
"InfoTip"="prop:DocComments"
[HKEY_CLASSES_ROOT\SHCmdFile\CLSID]
@="{57651662-CE3E-11D0-8D77-00C04FC99D61}"
[HKEY_CLASSES_ROOT\SHCmdFile\shell]
[HKEY_CLASSES_ROOT\SHCmdFile\shell\open]
[HKEY_CLASSES_ROOT\SHCmdFile\shell\open\command]
@="explorer.exe"
[HKEY_CLASSES_ROOT\SHCmdFile\shell\open\ddeexec]
@="[ShellFile(\"%1\",\"%1\",%S)]"
"NoActivateHandler"=""
[HKEY_CLASSES_ROOT\SHCmdFile\shell\open\ddeexec\Application]
@="Folders"
[HKEY_CLASSES_ROOT\SHCmdFile\shell\open\ddeexec\Topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\SHCmdFile\shellex]
[HKEY_CLASSES_ROOT\SHCmdFile\shellex\DropHandler]
@="{86C86720-42A0-1069-A2E8-08002B30309D}"
[HKEY_CLASSES_ROOT\SHCmdFile\shellex\IconHandler]
Edited by AndrewT (23/09/2007 21:45)
