Just in case anyone wants to do something else with this, here's the hack code...
import com.lowagie.text.DocumentException;
import com.lowagie.text.pdf.PdfNumber;
import com.lowagie.text.pdf.PdfReader;
import com.lowagie.text.pdf.PdfName;
import com.lowagie.text.pdf.PdfStamper;
import java.io.FileOutputStream;
import java.io.IOException;
public class RotatePages
    public static void main(String[] args)
        String fileName = "";
        String outFileName = "";
        int degrees = 0;
        String usage = "usage: RotatePages <input> <output> <degrees>";
        if (args.length > 2)
            fileName = args[0];
            outFileName = args[1];
            try
                degrees = Integer.parseInt(args[2]);
                if (degrees != 90 && degrees != 180)
                    System.out.println("Entered: " + degrees);
                    throw new NumberFormatException();
            catch (NumberFormatException e)
                System.out.println(usage);
                System.out.println("Please specify either 90 or 180 degrees.");
                return;
        else
            return;
        try
            System.out.println("Rotating all pages in " + fileName + " by "
                + degrees + " degrees.");
            PdfReader reader = new PdfReader(fileName);
            for (int p = 1; p <= reader.getNumberOfPages(); ++p)
                reader.getPageN(p).put(PdfName.ROTATE, new PdfNumber(degrees));
            PdfStamper stp = new PdfStamper(reader, new FileOutputStream(
                outFileName));
            stp.close();
            System.out.println("Writing " + outFileName + " ...");
        catch (DocumentException e)
            e.printStackTrace();
        catch (IOException e)
ricin
MkII/080000565
MkIIa/010101253
ricin.io
