Hi again,
Just so you know, if you aren't used to compiling your own software, I didn't post a binary of the program, just the source. I have to get a cross compiling environment set up to build a binary. I'll try to do that later today and post a binary.
Also, this requires the Hijack kernel to work. I had it set up so that I could launch it from the hijack menu. Also, I made a custom serial cable for the wideband that omitted one of the data lines so that the wideband didn't see the output from the kernel on boot.
-Jeremy
