builder_bigdisk_v3.upgrade
2.16 MB (2,267,745 bytes)
MD5 0b8b1f793a7e2a7e8253fad6a35afc41
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v504 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Mon Dec 29 23:29:04 EST 2008
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000512) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v504 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg power-pic driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffaa
ide_data_test: wrote 0x5555 read 0xff55
hda: TS64GSSD25-M, ATA DISK drive
hda: TS64GSSD25-M, 61136MB w/0kB Cache, CHS=7793/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:0
0
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init+ /bin/mount -n /proc
+ log 'Builder image'
+ echo 'Builder image'
Builder image
+ echo 'POPUP show_message("Builder image")
9999 Builder image'
+ DRIVE1=
+ '[' -e /proc/ide/hdb -a -e /proc/ide/hdc ']'
+ '[' -e /proc/ide/hdb ']'
+ '[' -e /proc/ide/hdc ']'
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0
+ '[' -d /drive0/fids ']'
+ /bin/umount /drive0
+ /bin/mkswap /dev/hda6
Setting up swapspace version 0, size = 16412672 bytes
+ /bin/swapon /dev/hda6
Adding Swap: 16028k swap-space (priority -1)
+ /bin/mkswap /dev/hda3
Setting up swapspace version 0, size = 24670208 bytes
+ /bin/swapon /dev/hda3
Adding Swap: 24092k swap-space (priority -2)
+ log 'Tuning hda5'
+ echo 'Tuning hda5'
Tuning hda5show_message("Tuning hda5")
+ echo 'POPUP 9999 Tuning hda5'
+ /bin/tune2fs -c -1 -i0 /dev/hda5
tune2fs 1.17, 26-Oct-1999 for EXT2 FS 0.5b, 95/08/09
Setting maximal mount count to -1
Setting interval between check 0 seconds
+ makedrive hda4 /drive0
+ dev=/dev/hda4
+ log 'Making hda4 filesystem'
+ echo 'Makishow_message("Making hda4 filesystem")
ng hda4 filesystem'
+ echo 'POPUP 9999 Making hda4 filesystem'
+ /bin/mkfs.ext2 -v -s 1 -i 131072 -m 0 /dev/hda4
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
Linux ext2 filesystem format
Filesystem label=
488256 inodes, 62492850 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
7629 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
        8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
        1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
        25600001, 53747713,
Writing inode tables: done
Writing superblocks and filesystem accounting information: show_message("1530.-1
 nomem err")
VM: do_try_to_free_pages failed for mkfs.ext2...
show_message("1530.-1 nomem err")
#080000512 green 12GB
