Ok, than that must be my case. For some reason I got one of those, because the difference is really noticeable. As you said, I am the only one reporting this, that's why until I actually tried the red fascia I did not expect that that could be the problem. But now I can definitely tell you that the BLUE I have is much much less readable than the red. No comparison whatsoever.
Now, I already requested at carsupport a AR blue replacement fascia. If the regular non AR blue (not the "dark" one I got) is even more readable that the non AR RED I have, than I'll get it, I don't really mind if it is not AR. Do you think I can have one, or are you totally out of stock, including the non AR ones?
Thank you!
___________________________
MK II BLUE/RED 12GB #923
