thank you Roger, think i've done what was required of me now....
You don't need emplode to find the player. Read the FAQ entry I linked above to connect via hyperterminal and get a boot log.
If you don't want to use hyperterminal, perhaps PuTTy will work.
is this what you want?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v503 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Aug 14 22:07:32 EDT 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102578) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
show_message("Hijack v503 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xffd0
ide_data_test: wrote 0xffff read 0xffd0
ide_data_test: wrote 0xaaaa read 0xabd0
ide_data_test: wrote 0x5555 read 0x55d0
ide_data_test: wrote 0x0000 read 0x1fd0
ide_data_test: wrote 0x0000 read 0x1400
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: FUJITSU MHN2300AT, ATA DISK drive
ide_data_test: wrote 0x0000 read 0xffff
hda: FUJITSU MHN2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:1
2
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Compl Starti
ng player
Timezone: GB-Eire
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
Vcb: 0x4086d000
Dead temp.sensor, status=0x00
wouldn't be a dead temp sensor would it? lol.
Hugh
www.dragon-signs.com
