I have a mkIIa unit that I haven't had any issues with until recently, when I upgraded from a 100gb Fujitsu drive to a white label 320GB pata drive with a model # HM321HC.
The unit is currently running 2.01 Developer version and has Hijack 5.18 installed. I was able to use the big disk builder v6 to get the drive set up
so that Emplode would see the correct capacity.
After doing over 10 or so syncs, I had an error while doing a final sync with Emplode. I'm unable to use Emplode or Jemplode with the player, as they reboot the player and times out while the "Building music databases..." step is processing. (Takes 25 min or so)
I checked rio car dot org and tried all of the different suggestions for using fsck and e2fsck to try and fix the partition. I'm getting this error:
"The filesystem size (according to the superblock) is 78116062 blocks
The physical size of the device is 33527655 blocks
Either the superblock or the partition table is likely to be corrupt!
Abort? yes
Any ideas?
