Ugh. This can't be good (see bolded lines).
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50-hijack (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Sun Jan 6 19:37:40 EST 2002
empeg-car player (hardware revision 9, serial number 30103046)
Command line: mem=16m
Memory: 15000k/16M available (976k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e6
Partition check:
hda:waiting for connections
hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
Starting player
player.cpp : 550:empeg-car 2.00-beta7 (internal) 2001/12/22.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1335 Dec 22 2001
Vcb: 0x408cd000
! mp3_decoder.cpp :1052:Failed to seek to offset 1118557, error=0xc0044000
-- JD - SN# 040104008 (120GB Blue, Digital Out)
