OK, I am trying to think this one through but am having a little probelm. I have the Power and Ign Sense connected to the 12V+ feed from the power supply. Ground is to earth and the other wires are just hanging in free space. The Empeg starts to boot then hangs because it seems to not be able to find the drives. If I plug in the unit with the normal AC plug, it works fine. If I plug it into my car sled, it works fine. So I am thinking I need to connect one of the 3 remaining wires (Ing Sense, Lights on, and/or tel. Mute) to something but I am not sure what. This is what I get from terminal:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
On DC power, quick boot
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #213 Sat Jun 23 16:35:13 BST 2001
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m temp=28 noinitrd
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: no response (status = 0x80)
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:1
0
VFS: Cannot open root device 03:05
