IIRC, the only reason the player uses the ID3 tag is if it is present in the MP3. If it's not in the file, it takes the filename and uses that. This means you could bulk strip the 3v1 tag for your entire collection; I use MP3 Tag Studio. As Tony recommends elsewhere, it's a good tool and worth paying for. The author is receptive to suggestions and your ideas may be taken on board for a future version. At the moment it is not script controlled and requires manual work, however.
One of the few remaining Mk1 owners... #00015
