Hi,
For various reasons, I need a nice and simple piece of software which will do conversion from MPx (2 or 3) to WAV (PCM, 44.1KHz, 16 bit). I don't need anything fancy - ideally it should be drag and drop (if Windows) or command line (Lin/Win) and default to putting new files in the same directory as the existing ones with the same filename (but different extension, obviously).
All that I've found have been designed to do much more than I actually need them to and, as a consequence, are too fiddly.
Any ideas?
Cheers and apologies for posting this here - it's the only place I know which may have the right answers!!
Nicholas.
18GB red s/n 080000299, original pos'n 8724. Reproduction of this post is not permitted.
-- 18GB red s/n 080000299
