I was incorrect. Upon doing a cold reboot I find that it is still locking up.
This is what comes through....
empeg-car v0.04 19990121 (altman@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux......................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50 (mcomb@grovepc) (gcc version 2.95.2 19991024 (release)) #7 Sat Nov 10 22:06:57 PST 2001
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00102)
Command line: mem=8m
Memory: 7296k/8M available (600k code, 20k reserved, 272k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
AD520B->B94615 11358731->12142101
AD520A->B94614 11358730->12142100
AD5242->B9460A 11358786->12142090
AD5243->B9460B 11358787->12142091
AD5212->B9461B 11358738->12142107
AD521A->B9461F 11358746->12142111
AD520C->B9460E 11358732->12142094
AD5240->B9460D 11358784->12142093
AD5241->B9460C 11358785->12142092
AD521E->B9465E 11358750->12142174
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005380).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: IBM-DJSA-230, ATA DISK drive
hdc: IBM-DARA-218000, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
ide1 at 0x000-0x007,0x038 on irq 6
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdc: IBM-DARA-218000, 17297MB w/418kB Cache, CHS=37488/15/63
Partition check:
hdc: hdc1 < hdc5 hdc6 > hdc2 hdc3 hdc4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
Also why is naming the drives "hda" and "hdc" instead of
"hda" and "hdb" ?
