>Why do your parameters for config.ini have semicolons in front of them?
Because Emplode used to mangle any lines that it doesn't recognize, except for those with semi-colons at the front. So I used semi-colons.
But now that I'm also using the '=' syntax, Emplode seems to be happier about it, so you should do your lines without semicolons now. I'll update the webpage.
Also, I forgot to say, the ";debug" option is no longer allowed (it is now the default behaviour).
Edited by mlord (17/11/2001 17:05)
