Announcing
the Latest,
the Greatest,
the Best Hijack kernel yet!
Hijack v79 is now available from
http://rtr.ca/empeg/. Get it while it lasts (hopefully a long time..).
Changes since v78:
-- independent "Knob Press Redefinition" actions saved for car / home
-- new options for "Knob Press Redefinition": [default], PopUp, VolAdj+, Details, Hush, Info, Mark, Shuffle
-- minor bugfix in read of config.ini (used to fail on "empty" players; may still!)
-- temperature now displays correctly on Vitals screen
-- the High Temperature Warning range is reduced to 35C - 65C (saves one bit in flash)
The "PopUp" knob setting causes each subsequent quick-knob-press to pop-up a small window from which a desired action can be chosen. Options on the pop-up menu include: [default], Details, Hush, Info, Mark, Repeat, Shuffle, Visual
In both menus, "[default]" means "factory default", without any "VolAdj" pop-ups, so selecting this will launch the Volume, Loudness, Balance, .. cycle of sound settings.
Together with separate knob settings for car/home, that oughta keep most of us happy.
Enjoy,
