How did you handle the depth of the Empeg cage? If I slide it all the way in, the Empeg is inset too far. I need to pull it out 1/4" or so, but over time the cage will slide back in. I can probably bend some of the tabs to keep it from coming out, but it looks like the tabs are too deep to keep it from going all the way in. Do you remember what your installer did?
