I used three 20-Ohm resistors in series.
One lead from the first resistor was soldered across the left four pins of the Sip pack pads which navigate to each LED.
I enclosed the resistors with heat shrink tubing and grounded the whole thing on the ground side of the big electrolytic caps on the back of the display board. Overkill really.
12Gb MKII 080000516 Blue 20Gb MKII 010101303 Green 20Gb MKII 090001020 Green 30Gb MKII 10101980 Blue
